Home > Technical (L322) > Coolant Level Low (after having oil cooler changed)
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hello all.
I had the oil cooler changed on my 4.4 TDV8 Westminster
I have had a bad oil smell still for sometime afterwards, but thats fading. However, as soon as I drive a few miles, the "COOLANT LEVEL LOW" light comes on.
The Garage have had it back 3 times now, last time for a week and they cannot find an issue.
Any suggestions from you clever folk welcome please?
ET
Post #703622 2nd Nov 2024 8:51pm
PeteT80
Is it actually losing coolant? as the coolant level low message is a common fault, fixed by either changing the sensor or the coolant reservoir itself.
Post #703623 2nd Nov 2024 9:03pm
TeeMyob
thank you for the reply, no, not losing coolant
Post #703624 2nd Nov 2024 9:06pm
PeteT80
It’ll probably be the sensor, easier to change the whole coolant reservoir.
Post #703625 2nd Nov 2024 9:09pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
It’s not unusual for a failing oil cooler to contaminate the coolant with oil which then shows up in the expansion tank, requiring replacement as part of the job, as well as a thorough flushing of the system.
Was your tank changed, perhaps the sensors electrical connector hasn’t been pushed home fully? Jonathan
2007 Defender 90 XS Hardtop
Post #703626 2nd Nov 2024 9:23pm
Change the tank, its £30ish and they often fail when you drain the coolant to perform a job... Thumbs Up
Post #703631 2nd Nov 2024 10:04pm
