Home > Technical (L322) > adjusting the track
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
adjusting the track
having trouble adjusting the track, cant unscrew the arm
i have undone the locking nut and knocked the tapered collar back, but it wont undo, its not rusted
am i missing something RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #703026 25th Oct 2024 5:35am
Pawl
You have a few options :
Try applying heat to the area and see if that might loosen the hold
Try repeating application of wd40 or similar - over a few days.
Worst case is remove the rod end at the hub and then the rack 'drum stick (as its often known) at the rack and then try again on the bench before giving up and replacing with new parts that have been greased to reduce the likelihood of it siezing again.
Having to remove the "assembly" is quite common ! Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #703035 25th Oct 2024 9:36am
knares
thanks RR 2005 4.4 petrol
Post #703058 25th Oct 2024 1:20pm
JamesDarby
United Kingdom 2011 Range Rover Autobiography TDV8 Buckingham Blue
I recently had to adjust mine. Took a fair amount of heat. Once hot apply candle wax to the thread and it seeps down the thread. Came loose eventually.
Got it a bit wrong first time I adjusted and the steering wheel was at an angle - all kinds of errors when tried to drive it - didn't like the steering wheel being at an angle. 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #703069 25th Oct 2024 4:03pm
knares
how did you measure the track. ????
i got it to turn, stilsons did the trick, but i think i might have got it wrong, gone to far, will have to measure it again RR 2005 4.4 petrol
Post #703399 30th Oct 2024 8:31am
JamesDarby
Hi
You can do it with Strings. See below as an example
https://www.instructables.com/DIY-Precise-Alignment-Toe-in/
There are a couple of web sites that let you enter the numbers and it tells you the settings.
or you can use like a big calliper like the 'Longacre Toe In Gauge' google it to see images.
But you could make something similar. I think Gunson also do something that you can drive over that tells you the toe setting. 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #703405 30th Oct 2024 9:35am
GraemeS
Australia
I have an adjustable rod and 2 blocks to rest the rod ends on, setting the rod to the distance between the front sidewalls then roll the vehicle forwards or backwards until the same measure point is at the back to measure the distance at the back, then adjust the toe each side to gradually make the distances the same, rolling the mark on the tyres back and forth for each measurement. One time it was so close that the wheel aligner didn't need to touch it.
Post #703406 30th Oct 2024 9:56am
