![]() | Home > Technical (L322) > adjusting the track |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 704 ![]() ![]() ![]() |
You have a few options :
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 781 ![]() ![]() ![]() |
thanks RR 2005 4.4 petrol
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 25 ![]() ![]() ![]() |
I recently had to adjust mine. Took a fair amount of heat. Once hot apply candle wax to the thread and it seeps down the thread. Came loose eventually.
how did you measure the track. ????
Hi
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2639 ![]() ![]() |
I have an adjustable rod and 2 blocks to rest the rod ends on, setting the rod to the distance between the front sidewalls then roll the vehicle forwards or backwards until the same measure point is at the back to measure the distance at the back, then adjust the toe each side to gradually make the distances the same, rolling the mark on the tyres back and forth for each measurement. One time it was so close that the wheel aligner didn't need to touch it. |
