Home > Technical (L322) > L322 4.4 TDV8 putting out clouds of white smoke at idle.
Page 4 of 4 <1234
Strobe84
Hey. Did you ever get to the bottom of this?
Post #715750 8th Apr 2025 6:30am
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Ask me again in a few days. There were a lot of red herrings which made no difference. However I hope we've got it cracked but won't know for another few days as I'm awaiting parts.
You're obviously asking for a reason. What are you trying to resolve? Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #715759 8th Apr 2025 12:49pm
D3Jon
I know you've mentioned the fuel rail pressure drop, which leads you to think it's got a dripping injector, which would cause nearly all of your symptoms (except I'd expect the smoke to clear shortly after start-up as the excess fuel in the cylinder is burnt off).
But, have you checked your brake fluid level?
That amount of white smoke would make me think it's sucking brake fluid through the servo into the intake manifold.
Just a thought?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #715762 8th Apr 2025 2:10pm
Dijit
D3Jon, No its not brake fluid but thanks for the suggestion. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #715792 9th Apr 2025 12:08am
Strobe84
Yes. I've got a similar issue with my 4.4... I've noticed that under certain conditions it smokes quite heavily then clears. It seems to be a mixture of blue, but mostly white "smoke" which I can't determine between steam and smoke. It seems to be that if it's been sat idling for a while, then I drive away, after a while it'll start doing it. If I don't idle it, it doesn't seem to do it... It doesn't idle rough, there's a slight "rattle" only heard from inside the cabin which we've put down to a small amount of chain slap but that's it.
Post #715814 9th Apr 2025 9:26am
dhallworth
Strobe84 - That'll be your secondary turbo. Oil builds up in it as they idle or are driven gently and when you put your foot down and spool up the 2nd turbo it clears the oil as smoke.
Look up 4.4 TDV8 Oil Drain Modification and you'll find it well documented.
Driving it spiritedly a couple of times a week once it's up to temperature will stop this.
Post #715825 9th Apr 2025 11:37am
Strobe84
I'm pretty certain I didn't spool the second turbo and it was still doing it. Also... Why white? Oil burn should be blue, no?
Post #715826 9th Apr 2025 12:20pm
fisha
No, oil burn is typically white. Used to be an easy way to tell if the timing on the older diesel engines was on its way out ... it would puff white.
Dark haze going towards dark smoke is over-fuelling. V8 or else ...
Post #715853 9th Apr 2025 7:58pm
D3Jon
Generally when engines burn oil, the smoke colour produced is regarded as grey or blue/grey. Not white.
White smoke is normally from coolant entering the combustion chambers or contaminated fuel (i.e. water or other substance in it). Brake fluid getting into the inlet system via a faulty servo also produces copious amounts of white smoke, but the OP has confirmed brake fluid levels are ok.
2014 Disco 4 HSE
Post #715954 11th Apr 2025 12:54pm
Page 4 of 4 <1234
