![]() | Home > Technical (L322) > oh no! idle squeal on V8 RR 2004 - only just bought it :( |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
also check the belt for cracks and wear ....you may have to take it off to do this "RANGEISM WILL NOT BE TOLERATED"
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
well guys...
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
You would be as well changing both belts whilst you're at it. Release the tension on pulley number 5 and slip the belt off, then remove the tension on pulley number 7 and slip the second belt off. Refitting is reversal.
Holly Cow !!! |
i thought it was your belt ...any way you can get to it either way from the bottom or the top if your not very tall like me get a crate |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
if you have a squeak, get it sorted. The chances are it is the tensioner pulley or idler puller. Mine was - the bearing was on the way out.
Could it really still be the pulleys or tensioner. What I dont understand is that if I have poured water on the belt and it stops squeaking then it must be the belt surely? If it actually was the pulleys or tensioner would it not still make a squeal regardless of water or am I wrong? Cheers |
It's not a big job to change the belts, change them first and see if the squeal goes away |
Yeah sounds like a plan. I'll change the belts first. Any steps on how to do this? |
Take it along to John's (47p2) garage and he'll do it FOC , really really kind guy …. |
As above, release the tension and remove the belt. The tensioner will have a bolt at one side which is for releasing the tension, I've not worked on a V8 engine so cannot tell you what size the bolt will be. If you have the space use a 12 point socket on the bolt, if not it will need to be a ring spanner. |
John thanks for the steps. I'll do some research and might even do a write up for it. Do you really have a garage I wasn't sure if mick was pulling my leg lol |
Yeah although its his own private one , but it is a Belter , if only i can find the picture of it |
A write up would be good. Mick's always pulling something, and not usually someones leg ![]() ![]() |
