![]() | Home > Technical (L322) > oh no! idle squeal on V8 RR 2004 - only just bought it :( |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
harman karden sounds like ice cream.. |
You must have the cheaper version of Harman Karden, coz i have Harman Kardon |
...and i only copied your spelling ... |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Mick you keep a tranny in your car............. |
trust you to think of the 'alternative' meaning tim.... |
Have you considered that it may just be that the belt is worn? If it has a frayed edge it may be rubbing on something.
Or summat else. depending on where you happen to be in the world......Thailand for example. ![]() ![]() |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Well it diddnt even cross my mind purely on the basis that these belts are meant to last atleast 100k however i have read that some people have changed them well before this limit. could it really be worn ? I am assuming we are talking about the same belt ? the serpentine belt ? I dont know when the belt was replaced last I have only just bought the car but it was serviced at 60k from land rover main dealer and then smaller oil service was done at a local garage at 64.5k just before i bought it but i dont know much history other than that, it now has 65k on the clock. thats the thing that is bothering me, i dont want to ignore it, if it can cause me more trouble later. i really wish I could do this type of work myself, even if I had a mechanic friend or a person in the know to help me... lol first time ive had a v8, i love my cars but made the unfortunate career choice of becoming an accountant ![]() |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
did you not check the fanbelt .... |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
i had this when i first bought mine ,the noise would go away after 5 minutes.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
My SC developed a squeak which was fixed by a new main drive belt pulley and belt. |
algt2 Member Since: 01 Jan 2011 Location: Edinburgh Posts: 65 ![]() ![]() ![]() |
Had the same issue at idle but over a month or so it got worse and ended up present all the time, turned out to be the tensioner, got it done and new belt fitted at the same time cost about £200 if i remember rightly. |
I had a look at it and it seemed ok. Any proper way of checking it? I'm on my way home now after another exciting day ![]() |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
trickle a little water on the belt whilst the engine is idling, if the belt is the problem it will temporarily quieten whilst wet. Do not be tempted to spray with WD40 or similar |
