![]() | Home > Maintenance & Mods (L322) > Boot Trim Fixing Woes |
Heavy duty Velcro tape. 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Yep, I've also had some success with hot glue, don't use too much and you can get it off again with careful use of a hot air gun... |
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 59 ![]() ![]() ![]() |
Cheers chaps. I'll give them a whirl. Heavy duty velcro sounds like a winner as no doubt I'll need to get back under there at some point! |
When I used some heavy duty velcro the glue melted in the interior heat build up of a bright summer day...!!! and it fell off....
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 106 ![]() ![]() ![]() |
remember a similar issue with the A pillar trim on my Discovery, i ended up making the missing clips from some plastic sheet of the correct thickness then stuck them to the trim piece with pipe solvent (see a plumbers merchant).
Cheers guys. Pipe solvent sounds like something I need to add to the garage. |
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 34 ![]() ![]() ![]() |
Depending on how important visual aesthetics are I fitted 2 x M5 screws as shown. The lower part is held in place by a lip and the location of the screws is fairly important so it doesn't crush the panel when tightening. You could use self tappers but being as the steel panel is only 1 mm thick a 4mm hole allowed the screws to bite as they don't need to be that tight. My panel is solid and does not rattle. The advantage over glue is its easily removed I guess
Thanks chaps. |
