Home > Maintenance & Mods (L322) > Boot Trim Fixing Woes
jamiej
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all,
My L322 boot trim piece has lost all its lugs which help hold it place Crying or Very sad
This is the piece which covers the wiper motor.
Has anyone devised an ingenious way of re attaching it ... Without the clips ?
Post #702435 18th Oct 2024 9:31am
JayGee
Heavy duty Velcro tape. 2012 TDV8 Vogue (L322)
Post #702445 18th Oct 2024 10:24am
Yep, I've also had some success with hot glue, don't use too much and you can get it off again with careful use of a hot air gun... Thumbs Up Pete
Post #702448 18th Oct 2024 10:33am
jamiej
Cheers chaps. I'll give them a whirl. Heavy duty velcro sounds like a winner as no doubt I'll need to get back under there at some point!
Post #702451 18th Oct 2024 10:45am
When I used some heavy duty velcro the glue melted in the interior heat build up of a bright summer day...!!! and it fell off....
Maybe get a roll of 3M VHB tape to put on the velcro or use the hot glue which holds to a higher temp and is easy to remove... Thumbs Up Pete
Post #702455 18th Oct 2024 11:04am
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
remember a similar issue with the A pillar trim on my Discovery, i ended up making the missing clips from some plastic sheet of the correct thickness then stuck them to the trim piece with pipe solvent (see a plumbers merchant).
As i remember the bits i made were very rough approximation but it worked and they are still attached to the pillars despite being took off numerous times.
Post #702486 18th Oct 2024 4:48pm
jamiej
Cheers guys. Pipe solvent sounds like something I need to add to the garage.
Post #702548 19th Oct 2024 7:48am
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
Depending on how important visual aesthetics are I fitted 2 x M5 screws as shown. The lower part is held in place by a lip and the location of the screws is fairly important so it doesn't crush the panel when tightening. You could use self tappers but being as the steel panel is only 1 mm thick a 4mm hole allowed the screws to bite as they don't need to be that tight. My panel is solid and does not rattle. The advantage over glue is its easily removed I guess
 Current: 2003 TD6 HSE. 161,000 miles
Previous 1993 Classic 3.9
Post #702601 19th Oct 2024 4:12pm
jamiej
Thanks chaps.
Post #702608 19th Oct 2024 5:41pm
