Home > Maintenance & Mods (L322) > Floppy Deployable Side Step? Motor gone?
GGDR
hi guys
My driver side deployable side step wasn't retracting all the way then when I was lubing them (spray) I opened the drivers door to extend them and I heard a real thump/crack sound.
Now it is not retracting and/or floppy. Meaning I can move it up and down with my hand. The pass side does not d that...
Motor gone? Gears?
Any tips very welcome.
. Cheers, Greg
Post #701496 4th Oct 2024 5:58pm
GGDR
looking a bit more of this firstly I've read most issues lie with (lack of) lubrication. In my case that may have been the cause of the crack sound but not now.
I can hear the motor whirring, and it sometimes pulls the step up a bit, but not all the way. And it's very floppy as I mentioned.
I think one of the drive gears gave way, does anyone know if they can be repaired?
There does not seem to be anything in the workshop manual. I can only find the fitting instructions pdf.
Any help appreciated.
. Cheers, Greg
Post #701533 5th Oct 2024 10:25am
Bolert
Frustrating, sorry to hear. Have deployables on mine. Lubricate every few months. Sounds like some of the gears may have snapped on the motor, so at it turns it catches the step.
Sure others on here may have some other ideas. Smile
Would you look to repair or remove the steps completely.
Good luck 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior
Post #701556 5th Oct 2024 5:29pm
GGDR
definitely keeping them, just searching for part numbers now...
. Cheers, Greg
Post #701572 5th Oct 2024 8:57pm
dpm
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Wedge key may have broken/fallen out.
Post #701586 6th Oct 2024 2:01am
GGDR
what's a wedge key pls?
do you have a part no?
. Cheers, Greg
Post #701592 6th Oct 2024 7:08am
dpm
Small metal wedge shape in the bracket that moves, have a look at the bracket that still works and you may see the part, it is held in place with a small bolt, no part number, but look on line at industrial engineer supply companies they may have some.
Post #701601 6th Oct 2024 9:48am
GGDR
thanks DPM, sounds like you had a similar issue?
did you get any pics by any chance?
. Cheers, Greg
Post #701746 8th Oct 2024 6:16am
dpm
Yes I did but can't remember where I got the wedge key from, it was a engineer supply firm on line i think. Sorry no pics I can just about manage to log on to the internet, clueless with tech.
Post #701809 9th Oct 2024 6:26am
GGDR
is this the wedge key?
in the centre of the bolts pack?
And does it fit where the long shaft has a flat section?
photo credit goes to Ebay Cheers, Greg
Post #706274 6th Dec 2024 5:09pm
Stuart-
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I've got a handful of those motors on the way from China to have a look at and bung on the site, but I probably won't have them for a few weeks yet.
I was actually meaning to ask the collective wisdom here if they are a part that tends to go. If so, I'll get a pallet of them in progress so I can have them well-priced. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #706278 6th Dec 2024 5:54pm
dpm
Yes GGDR They look like the wedge key.
Post #706404 8th Dec 2024 5:34pm
cass
My experience of these steps is that the motors seem quite robust, I think the biggest problem is the brackets/hinges seizing or getting damaged by idiots with trolly jacks. When I wrecked one of mine I found that they were ridiculously expensive (and are now unobtainable) and the motor couldn’t be removed from the bracket without butchering the bracket.
You might be onto something if you can get brackets to sell with the new motors?
Post #706407 8th Dec 2024 6:12pm
Stuart-
I've already got brackets/hinges, stock is low, but three pallets of L322 and L405 are on the water as we speak.
Not intending to hijack the thread. 2017 4.4 SDV8 Autobiography in black
Post #706485 9th Dec 2024 6:01pm
GGDR
Still trying to work out how/where to buy a wedge key
Pics with steps out
Good side:
Floppy side
Does look like something is missing compared to the good side.
Does this show the wedge key missing?
Thoughts? Cheers, Greg
Post #706990 15th Dec 2024 9:41pm
