![]() | Home > Maintenance & Mods (L322) > Floppy Deployable Side Step? Motor gone? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
looking a bit more of this firstly I've read most issues lie with (lack of) lubrication. In my case that may have been the cause of the crack sound but not now.
Bolert Member Since: 29 Jun 2021 Location: Hythe, Kent Posts: 30 ![]() ![]() ![]() |
Frustrating, sorry to hear. Have deployables on mine. Lubricate every few months. Sounds like some of the gears may have snapped on the motor, so at it turns it catches the step.
definitely keeping them, just searching for part numbers now...
dpm Member Since: 14 May 2018 Location: grimsby Posts: 43 ![]() ![]() ![]() |
Wedge key may have broken/fallen out. |
what's a wedge key pls?
Small metal wedge shape in the bracket that moves, have a look at the bracket that still works and you may see the part, it is held in place with a small bolt, no part number, but look on line at industrial engineer supply companies they may have some. |
thanks DPM, sounds like you had a similar issue?
Yes I did but can't remember where I got the wedge key from, it was a engineer supply firm on line i think. Sorry no pics I can just about manage to log on to the internet, clueless with tech. |
is this the wedge key?
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 366 ![]() ![]() ![]() |
I've got a handful of those motors on the way from China to have a look at and bung on the site, but I probably won't have them for a few weeks yet.
Yes GGDR They look like the wedge key. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
My experience of these steps is that the motors seem quite robust, I think the biggest problem is the brackets/hinges seizing or getting damaged by idiots with trolly jacks. When I wrecked one of mine I found that they were ridiculously expensive (and are now unobtainable) and the motor couldn’t be removed from the bracket without butchering the bracket.
I've already got brackets/hinges, stock is low, but three pallets of L322 and L405 are on the water as we speak.
Still trying to work out how/where to buy a wedge key
