Home > Maintenance & Mods (L322) > gearbox Flush Essex recommendations |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
Read this...
12th Sep 2024 11:36pm |
Lefty84 Member Since: 11 Sep 2024 Location: Essex Posts: 14 |
I already called the number on his website but there was no answer and no call back, it’s also not clear where he’s based. Anyone in Essex do it? |
13th Sep 2024 12:16am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Bodsy is mobile so all over UK but is incredibly busy and booked up. Why? Because he’s bloody good at what he does. Patience is key. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Sep 2024 6:31am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7964 |
I found a text message to be the best way to arrange a booking.
13th Sep 2024 7:05am |
JimFos Member Since: 02 Apr 2023 Location: Norfolk Posts: 16 |
When I contacted Ian about my TD6 5 speed box, he replied that he does 6 and 8 speed only and recommended Martyn Hinds at Dartford Transmissions.
13th Sep 2024 8:58am |
Ok I’ll keep trying. If not I’ll go to Martin, he looked after our last one.
13th Sep 2024 10:01am |
Can't help you with price indication as in the end I decided to change trans fluid and filter rather than have it flushed. |
13th Sep 2024 3:25pm |
I don’t think Bodsy does the early gearboxes so I’d go with Martin Hind at DTA 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Sep 2024 6:28am |
Is it better to flush or just replace the pan & filter and put new oil in? |
18th Sep 2024 7:36am |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 41 |
I had a recent gearbox service (160000M interval) I asked the Indy whether he would flush it and he remarked ' unless you've had this flushed before I wouldn't recommend it' so I asked why and he said it would probably disturb any crap sitting against the housing and then it could float around later on.
18th Sep 2024 12:52pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 827 |
Does Bodsy use chemicals to get all the crap out first, before doing the Megaflush ??? |
18th Sep 2024 2:06pm |
I don’t think so. I’m certain he does a fantastic job. I’m just looking at what is better because the cost of a pan, gaskets and the oil doesn’t work out too bad if I do it myself.
18th Sep 2024 5:33pm |
