![]() | Home > Maintenance & Mods (L322) > gearbox Flush Essex recommendations |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Read this... |
Lefty84 Member Since: 11 Sep 2024 Location: Essex Posts: 15 ![]() ![]() ![]() |
I already called the number on his website but there was no answer and no call back, it’s also not clear where he’s based. Anyone in Essex do it? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Bodsy is mobile so all over UK but is incredibly busy and booked up. Why? Because he’s bloody good at what he does. Patience is key. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
I found a text message to be the best way to arrange a booking.
JimFos Member Since: 02 Apr 2023 Location: Norfolk Posts: 18 ![]() ![]() |
When I contacted Ian about my TD6 5 speed box, he replied that he does 6 and 8 speed only and recommended Martyn Hinds at Dartford Transmissions.
Ok I’ll keep trying. If not I’ll go to Martin, he looked after our last one.
Can't help you with price indication as in the end I decided to change trans fluid and filter rather than have it flushed. |
I don’t think Bodsy does the early gearboxes so I’d go with Martin Hind at DTA 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Is it better to flush or just replace the pan & filter and put new oil in? |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 66 ![]() ![]() ![]() |
I had a recent gearbox service (160000M interval) I asked the Indy whether he would flush it and he remarked ' unless you've had this flushed before I wouldn't recommend it' so I asked why and he said it would probably disturb any crap sitting against the housing and then it could float around later on.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
Does Bodsy use chemicals to get all the crap out first, before doing the Megaflush ??? |
I don’t think so. I’m certain he does a fantastic job. I’m just looking at what is better because the cost of a pan, gaskets and the oil doesn’t work out too bad if I do it myself.
