Home > Technical (L405) > Intermittent Headlight |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 |
Well my problem is pretty much as it says in the title. The drivers side headlight is intermittent - why do I know? because today I was sat in the car with the lights on and the light just went off and on then stayed on.
4th Sep 2024 1:45pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
further to my loose connection suggestion geoff, i think the bulb might be failing , possibly the filament breaking down..
4th Sep 2024 3:43pm |
OK I’ll get some bulbs ordered, D3S if my memory serves me. Any thoughts on which ones, I could do with a bit more brightness, these peepers of mine are getting old Geoff |
4th Sep 2024 5:04pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1434 |
My money would be on earth stud about to go, any other strange happenings? |
4th Sep 2024 5:19pm |
Actually there is another fault appeared and its a parking sensor problem, apparently they are not working. Failed about the same time as the Headlight became intermittent so I will check the earth stud - when I find it!! Geoff |
4th Sep 2024 6:50pm |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 250 |
Whichever side headlight is playing up, remove the front section of the arch liner on the same side as the faulty headlight and check the earth mounting stud, there will be 4 earths to the stud (2 eyelets with 2 cables attached to each eyelet). Give it a bit of a tug and it'll probably fall off. I seem to recall that the ABS module is affected by the o/s earth and is one of the first things to flag a fault. Nearside is PDC sensors, headlight and low coolant/bonnet open faults.
4th Sep 2024 8:35pm |
Also a good time to buy LED headlights - as an experiment. Geoff |
5th Sep 2024 6:22am |
Any LED recommendations? Geoff |
5th Sep 2024 1:10pm |
Ordered some cheapo HID replacements just to test - only about 20 quid. Geoff |
9th Sep 2024 11:48am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8348 |
Earth points....
9th Sep 2024 12:07pm |
