![]() | Home > Maintenance & Mods (L322) > L322 4.4 TDV8 AC Condenser Replacement Procedure? |
chiefracing Member Since: 24 Aug 2024 Location: Gloucestershire Posts: 14 ![]() ![]() |
Ive loosely asked the same question. Didnt really get an answer if its easier to remove the front or take off the fan etc.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
this is possibly worth a watch
This doesnt show the condenser job, just the compressor but thanks for the vid. |
maybe this one is better - looks like a helluva lot of work - good luck |
Jak Member Since: 28 Jun 2020 Location: Lytham, England Posts: 2 ![]() |
Yes, thanks for those. I've watched both and both useful - plus another that showed the tools required to get the fan blade off. But the 4.4 is a bit different from 3.6, and to me with all the AC pipes and bracketry, it doesn't look like you can remove the condenser core with it in the car. (sort of confirmed by the LR workshop manual procedure).
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
is possible, i done that - justr you need to remove full front. |
Im half way through condenser and belts/tensioners. Front off is a big job but with all the jobs I thought it easier..the condenser would be a nightmare if left in situ. Ive now found my intercooler rotten too and rust running from my ac compressor and bearings noisy so Im balls-deep๐คฆโโ๏ธ๐คฆโโ๏ธ.
Thats 4 hours in, its hanging like that because I had a bolt with a rotted head that holds the ac pipe to the fan cowl. That aside its just a lot of stuff to undoโฆand its all been there 10+ years!! |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 54 ![]() ![]() ![]() |
Whilst there, it might be worth changing the water pump, crankshaft pulley and checking the PAS pipes for corrosion. |
Fair points Steve but what am I gonna do next month?? ๐๐ |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 789 ![]() ![]() ![]() |
" a leak in the bottom centre of the condenser"
Mmmm |
Now to start bolting new stuff on-when it arrives! |
MicF Member Since: 04 Sep 2024 Location: South West Posts: 4 ![]() ![]() ![]() |
Hi all,
