![]() | Home > Maintenance & Mods (L322) > L322 4.4 TDV8 AC Condenser Replacement Procedure? |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 166 ![]() ![]() ![]() |
remove bumper, remove headlamps, remove fuel cooler (watch for tubes it bends easily) then few bolts, two was quite hard to reach,disconnect tubes and moves easy to the front. about 2-3 hours job |
MicF Member Since: 04 Sep 2024 Location: South West Posts: 4 ![]() ![]() ![]() |
Update...
Condenser removed on a 2012 4.4 TDV8 after removing grille, slam panel, radiator faring, fuel cooler radiator, air box and header tank
WestyP Member Since: 27 Jan 2025 Location: Westmeath Posts: 1 ![]() ![]() ![]() |
Hi Guys. I know this is an old post but Im facing into this job this week. MicF how did you remove the Radiator faring from the lower tabs. |
