Home > Maintenance & Mods (L322) > L322 4.4 TDV8 AC Condenser Replacement Procedure?
chiefracing
I cant see how you can swap the condenser without removing the front on a later 322 TDV8 4.4. Having stripped mine out its not actually a horrendous job, just lots of nuts and bolts and it makes the job easy. You maybfins, as I did, that your intercooler is rotten too! Good luck!
Post #699509 4th Sep 2024 9:09pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
remove bumper, remove headlamps, remove fuel cooler (watch for tubes it bends easily) then few bolts, two was quite hard to reach,disconnect tubes and moves easy to the front. about 2-3 hours job
Post #699510 4th Sep 2024 9:14pm
MicF
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Update...
Once the small fuel cooler radiator is removed (easy) the condenser slides out vertically. The rest of the radiator stack had to be pushed towards the engine by a few mm to allow this but there is no need to remove the cowl or fan.
It remains to be seen if fitting the replacement works out ok as the one I ordered is damaged so I am now awaiting another to be delivered.
What format to photos need to be in to upload? I have tried in HEIC format off my iPhone but I get an "Error retrieving album data" Reducing the file size to 199kB still doesn't work. I am using Safari.
Uploading photos straight from my iPhone seems to work.
Post #699530 5th Sep 2024 10:04am
MicF
Condenser removed on a 2012 4.4 TDV8 after removing grille, slam panel, radiator faring, fuel cooler radiator, air box and header tank
Post #699534 5th Sep 2024 10:59am
WestyP
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
Hi Guys. I know this is an old post but Im facing into this job this week. MicF how did you remove the Radiator faring from the lower tabs.
Post #711536 10th Feb 2025 10:16pm
