Home > Maintenance & Mods (L322) > Drivers side outer door handle not working
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Hi guys,
Unlocked the motor yesterday pulled on door handle, nothing. Something must have broken or come off. I am still able to open door from inside.
Have any of you had this happen, any help would be appreciated before I start stripping the door down. -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #698612 22nd Aug 2024 1:48pm
cable has probably snapped....loads on here re that , do a search Wink ... - .- -.
Post #698614 22nd Aug 2024 1:59pm
Giffer2018
Thanks for that. -----------------------
Post #698615 22nd Aug 2024 2:11pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Yes common for the cable to snap, changed my last year and think I paid about £20 from a certain website. Easy enough to change, I covered mine in lithium grease when fitting as the door is prone to freezing in the winter and the grease can help. Strangely the passenger door has never froze !
Post #698620 22nd Aug 2024 3:09pm
Merchy
Remove the door card for access, don't know about your year, but on a 2006 model I disconnected the battery and waited a while, because I had to remove the air bag for access, as the cylindrical section on the end of the cable was jammed inside the door catch mechanism. Good tip about adding grease to the parts Thumbs Up I bought an original replacement part that was not too expensive.
Post #698649 22nd Aug 2024 9:03pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
As others have said, the cable has most likely snapped, often near the end part that is attached to the inside of the door pull. Usually there should be minimal resistance felt, if any, while pulling the handle; that is the tell tale of a broken cable. In case the cable turns out to be fine, then the door lock is in need of adjustment. This is done by an Allen bolt concealed under a rubber grommet just above the latch mechanism.
Post #698660 23rd Aug 2024 7:03am
Giffer2018
Thanks for the help chaps. I have now ordered a cable, was very surprised at the great variation of prices for a short piece of cable. -----------------------
Post #698692 23rd Aug 2024 3:48pm
mjdronfield
Hopefully you can hold the unlock down on the fob so the window opens, then you can reach in and open it from the inside. Save you clambering across from the passenger side.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #698694 23rd Aug 2024 3:53pm
