![]() | Home > Maintenance & Mods (L322) > Drivers side outer door handle not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
cable has probably snapped....loads on here re that , do a search |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 60 ![]() ![]() ![]() |
Thanks for that. -----------------------
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Yes common for the cable to snap, changed my last year and think I paid about £20 from a certain website. Easy enough to change, I covered mine in lithium grease when fitting as the door is prone to freezing in the winter and the grease can help. Strangely the passenger door has never froze ! |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
Remove the door card for access, don't know about your year, but on a 2006 model I disconnected the battery and waited a while, because I had to remove the air bag for access, as the cylindrical section on the end of the cable was jammed inside the door catch mechanism. Good tip about adding grease to the parts |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
As others have said, the cable has most likely snapped, often near the end part that is attached to the inside of the door pull. Usually there should be minimal resistance felt, if any, while pulling the handle; that is the tell tale of a broken cable. In case the cable turns out to be fine, then the door lock is in need of adjustment. This is done by an Allen bolt concealed under a rubber grommet just above the latch mechanism. |
Thanks for the help chaps. I have now ordered a cable, was very surprised at the great variation of prices for a short piece of cable. -----------------------
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Hopefully you can hold the unlock down on the fob so the window opens, then you can reach in and open it from the inside. Save you clambering across from the passenger side.
