Home > Technical (L405) > Swan neck to 2” connector adaptor? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
The 2" recievers certainly used to exist for the L405, Red Merle had one fitted to his - Picture on page 2 - https://www.fullfatrr.com/forum/topic45243.html
19th Aug 2024 7:52am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
Yeah, your going to be using adapters on top of adapters on a ball swan neck and quite a heavy load with considerable weight on that lever point, which doesn't sound like a good idea. At best it's going to be unstable and wobble all over the place, most likely will just sink to the ground if it doesn't snap off at the ball joint.
19th Aug 2024 8:12am |
nambFFRR Member Since: 06 Aug 2018 Location: United Kingdom Posts: 191 |
I hear what you’re saying but given the swan neck is rated to 150kg, the bak rak adaptor is rated at 100kg and my need is to add 90kg the load on the swan neck is less than I normally load it for my caravan (my target and recommended towball weight is 100kg) I’m happy to try a receiver. The only potential turning moment will be in the bak rak adaptor as everything else are solid/bolted connections. Shame there isn’t a detachable 2” receiver adaptor which would be perfect. I don’t want to add anything like a ‘strap’ to the tailgate as mine is a composite (plastic) construction so very lightweight.
19th Aug 2024 10:03am |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 288 |
@nambFFRR
19th Aug 2024 11:56am |
That’s very kind of you Ivan
19th Aug 2024 2:28pm |
