Home > Technical (L322) > Where is the hood switch??
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Am trying to trace a battery drain, need to activate the hood/bonnet switch t put the car to sleep
Have got a picture of it in the workshop manual but I'm just being stupid and I cant find it under the bonnet, anybody give me some directions?
many thanks All the best
Chris
Post #697787 10th Aug 2024 2:55pm
Paddy X350
Found it.
Well I've found the switch, its holding bracket is broken and the switch is hanging down by the brake fluid reservoir! All the best
Chris
Post #697790 10th Aug 2024 3:17pm
PeteT80
On the drivers near the brake pipes next to the brake servo
Post #697792 10th Aug 2024 3:20pm
Paddy X350
Just a piece of information that I found out about the hood switch from the WSM that might be useful;
When the bonnet is open you can pull the plunger up on the switch and this simulates the bonnet closed position. So no need to stick something heavy on it to get a bonnet closed condition.
Also in the bonnet closed position the switch goes to open circuit, so you could just disconnect the switch to simulate that the bonnet is closed. All the best
Chris
Post #697961 13th Aug 2024 8:30am
mjdronfield
Indeed. The alarm can sometimes go off when the car sits in the sun, as the bonnet gets hot. I bent the bracket up slightly and put a rubber grommet on the end of the plunger to stop this. No issues since.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #697973 13th Aug 2024 9:25am
pcourtney
A picture is worth a thousand words Smile
The sensor is the plug with purple colour inside, the blue finger pointing to where it is connected !
Post #703583 1st Nov 2024 8:05pm
BigEnglishWagon
New Zealand 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Here is a couple of photos for an L322 2005 Hood Switch.
Once lifted up the computer box nearby has several happy mumblings.
Post #707621 26th Dec 2024 4:44am
BigEnglishWagon
Post #707622 26th Dec 2024 4:46am
