![]() | Home > Technical (L322) > 4.4TDV8 “engine system failure “ |
Brian McColm Member Since: 23 Apr 2024 Location: Lochmaben Posts: 6 ![]() ![]() |
Hi just fitted a new throttle body (was told if the throttle is chattering when ignition off then it’s more likely the cogs inside have worn ) went to start engine & “engine system fault” now and it won’t start only have errors P00CF-62 -P0235-16 coming up , the car has been in the garage for 11weeks and failed after 2days, garage says they want it back on Monday but i have no confidence in them TBH |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
In the Wiki is the full workshop manual for the 2010-12 L322 in downloadable format and this includes all the error codes; if you don't currently have a copy of this, it's an excellent source of reference for all things L322 (and the DTC's that they can generate).
Sorry I’m new to this Forum can you point me to this WIKI |
If you look to the right of the banner at the top of the site, just under fullfatrr.com, the third link is the wiki. https://www.fullfatrr.com/wiki/Main_Page 2011 Range Rover Vogue SE 4.4 TDv8 |
Thank you |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
It seems like an electrical fault but I would get it back to the garage to let them sort it out. |
Hi GraemeS you were right it was electrical issue all fixed now thanks |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 83 ![]() ![]() ![]() |
Good to hear it's sorted , Did they say what the specific issue was? Poorly made connection post-maintenance coming loose maybe |
