Home > Technical (L322) > 4.4TDV8 “engine system failure “ |
Brian McColm Member Since: 23 Apr 2024 Location: Lochmaben Posts: 6 |
Hi just fitted a new throttle body (was told if the throttle is chattering when ignition off then it’s more likely the cogs inside have worn ) went to start engine & “engine system fault” now and it won’t start only have errors P00CF-62 -P0235-16 coming up , the car has been in the garage for 11weeks and failed after 2days, garage says they want it back on Monday but i have no confidence in them TBH |
7th Aug 2024 4:06pm |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 |
In the Wiki is the full workshop manual for the 2010-12 L322 in downloadable format and this includes all the error codes; if you don't currently have a copy of this, it's an excellent source of reference for all things L322 (and the DTC's that they can generate).
7th Aug 2024 4:10pm |
Sorry I’m new to this Forum can you point me to this WIKI |
7th Aug 2024 4:19pm |
If you look to the right of the banner at the top of the site, just under fullfatrr.com, the third link is the wiki. https://www.fullfatrr.com/wiki/Main_Page 2011 Range Rover Vogue SE 4.4 TDv8 |
7th Aug 2024 4:35pm |
Thank you |
7th Aug 2024 4:39pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2489 |
It seems like an electrical fault but I would get it back to the garage to let them sort it out. |
7th Aug 2024 8:36pm |
Hi GraemeS you were right it was electrical issue all fixed now thanks |
29th Sep 2024 3:45pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
Good to hear it's sorted , Did they say what the specific issue was? Poorly made connection post-maintenance coming loose maybe |
2nd Oct 2024 12:02pm |
