Home > Technical (L322) > 4.4TDV8 “engine system failure “
Brian McColm
2010 Range Rover Vogue SE TDV8 Baltic Blue
Hi can someone help with a fault I have 4.4tdv8 2010 “engine system failure “ came up and no throttle, slowly drove to a service station and AA and popped the bonnet found the throttle body clicking away even with the ignition off, used my IID tool and got these errors, not sure where to go with this any help very much appreciated
Post #697357 3rd Aug 2024 6:59pm
Brian McColm
Hi just fitted a new throttle body (was told if the throttle is chattering when ignition off then it’s more likely the cogs inside have worn ) went to start engine & “engine system fault” now and it won’t start only have errors P00CF-62 -P0235-16 coming up , the car has been in the garage for 11weeks and failed after 2days, garage says they want it back on Monday but i have no confidence in them TBH
Post #697560 7th Aug 2024 5:06pm
Ian Donkin
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
In the Wiki is the full workshop manual for the 2010-12 L322 in downloadable format and this includes all the error codes; if you don't currently have a copy of this, it's an excellent source of reference for all things L322 (and the DTC's that they can generate).
Hopefully things will get better for you - the late 4.4TDV8 is a lovely thing when working correctly. 2011 Range Rover Vogue SE 4.4 TDv8
Post #697561 7th Aug 2024 5:10pm
Brian McColm
Sorry I’m new to this Forum can you point me to this WIKI
Post #697562 7th Aug 2024 5:19pm
Ian Donkin
If you look to the right of the banner at the top of the site, just under fullfatrr.com, the third link is the wiki. https://www.fullfatrr.com/wiki/Main_Page 2011 Range Rover Vogue SE 4.4 TDv8
Post #697564 7th Aug 2024 5:35pm
Brian McColm
Thank you
Post #697565 7th Aug 2024 5:39pm
GraemeS
Australia
It seems like an electrical fault but I would get it back to the garage to let them sort it out.
Post #697584 7th Aug 2024 9:36pm
Brian McColm
Hi GraemeS you were right it was electrical issue all fixed now thanks
Post #701081 29th Sep 2024 4:45pm
RovingCanary
Good to hear it's sorted , Did they say what the specific issue was? Poorly made connection post-maintenance coming loose maybe
Post #701283 2nd Oct 2024 1:02pm
