Home > Technical (L322) > Wonky wange wover |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8252 |
I'd guess a dodgy height sensor.... Pete
2nd Aug 2024 4:34pm |
beeza Member Since: 20 Oct 2021 Location: Dominican Republic Posts: 24 |
Would that show up as a fault or a stored code? Because it's not display any. 2010 L322 5.0l Supercharged
2nd Aug 2024 5:25pm |
I believe they can just give a wrong height, the system believes them as it has no way to verify...
2nd Aug 2024 6:24pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Won't show a fault but you can look at the live values for the wheel heights when it's on level ground and see if a value looks out of place or a value doesn't change when raising or lowering the suspension. Faults can be electrical or physical i.e a broken, loose or partialy seized height sensor connector arm. 2012 TDV8 Vogue (L322) |
2nd Aug 2024 7:01pm |
