Home > Technical (L322) > Wonky wange wover
beeza
England 2010 Range Rover Supercharged 5.0 SC V8 Java Black
Wonky wange wover
My left rear is an inch higher than it should be.
I have the GAP IID tool and I tried calibrating the height with a tape measure and the guided calibration function. Once I set the correct heights on all four corners and save it, it says select up or down on the EAS control switch. Once I do that, it goes back to being wonky again. What am I doing wrong? 2010 L322 5.0l Supercharged
2008 L322 Vogue 3.6 VDV8 (The wife's)
Post #697269 2nd Aug 2024 4:14pm
I'd guess a dodgy height sensor.... Pete
Post #697270 2nd Aug 2024 4:34pm
beeza
Would that show up as a fault or a stored code? Because it's not display any. 2010 L322 5.0l Supercharged
Post #697275 2nd Aug 2024 5:25pm
I believe they can just give a wrong height, the system believes them as it has no way to verify...
Remove the sensor, put live values on the IID, move the sensor and hopefully you will see something.
This is speculation as I've not dealt with the same symptoms... Thumbs Up Pete
Post #697282 2nd Aug 2024 6:24pm
JayGee
Won't show a fault but you can look at the live values for the wheel heights when it's on level ground and see if a value looks out of place or a value doesn't change when raising or lowering the suspension. Faults can be electrical or physical i.e a broken, loose or partialy seized height sensor connector arm. 2012 TDV8 Vogue (L322)
Post #697295 2nd Aug 2024 7:01pm
