![]() | Home > Technical (L322) > Flashing Low Range Light how to reset? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
Try puting it into neutral and then cancelling low range ie. Select high range. John
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
…and if that doesn’t work, you could try the Fuse 37 trick:
NickHS Member Since: 24 May 2024 Location: Gdansk Posts: 11 ![]() ![]() ![]() |
Thanks Phil your input was the key and thanks very much as the car is now functioning, my RR fix angel.
