Home > Technical (L322) > Flashing Low Range Light how to reset?
NickHS
Poland 2003 Range Rover Vogue 4.4 V8 Giverny Green
The low range light is constantly flashing and there are no gears, how to reset or what is the cause.
We were only bleeding the brakes.
There is a constant message which I can not read on the depixelated display possibly transfer - neutral??
Any help would be fantastic.
Post #697156 30th Jul 2024 6:26pm
Weegie
Try puting it into neutral and then cancelling low range ie. Select high range. John
GAP iiD BT-Sold
Post #697160 30th Jul 2024 7:50pm
RRPhil
…and if that doesn’t work, you could try the Fuse 37 trick:
1) Fit spare fuse into position 37 in main fuse box
2) With transmission in Neutral, switch ignition on
3) Switch off ignition
4) Remove fuse from position 37
5) Switch ignition on
6) Operate switch to perform a high to low range shift and then back to high range
Phil
Post #697161 30th Jul 2024 8:16pm
NickHS
Thanks Phil your input was the key and thanks very much as the car is now functioning, my RR fix angel.
That is why these forums are so fantastic I am also on Disco3.
Post #697180 31st Jul 2024 10:12am
