Home > Technical (L405) > Check coolant level
Danwilderspin
Check coolant level
Went to look at a 4.4 sdv8 and it had check coolant level on the dash… had a few other issue like damaged headliner due to block drains and causing water ingress which I’m happy to take a punt on but the check coolant level the guy claims it’s a dodgy sensor would you keep looking or run a mile? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #696804 24th Jul 2024 12:12pm
dingg1
Is the coolant level low?
If it is just a dodgy sensor, it wouldn't put me off. But if the present owner hasn't bothered to fix it, what else has he not bothered fixing??
Post #696807 24th Jul 2024 12:42pm
caymanblack
The water drains would worry me more , check on here about this. overfinch modified
Post #696808 24th Jul 2024 1:00pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Personally I would have run a mile at the first mention of 'blocked sunroof drains' let alone having the 'check coolant' light as well. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #696811 24th Jul 2024 1:21pm
Sunroof drains is a fairly easy, if not quick, fix and not a lot of money if you can do it yourself.
Coolant loss could be a lot of things including the common failure of the heater pipe at the rear which goes under the subframe, you can use a length of hose to replace it.
Or it could be the oil cooler or any number of hoses....
If the price is cheap enough then why not... Pete
Post #696814 24th Jul 2024 1:37pm
garyRR
As the miles creep up and the rubber gets older, they can use a little bit of coolant, especially as the SDV8 has about 15,000 miles of pipework. 2015 Range Rover Autobiography 4.4 SDV8
Post #696826 24th Jul 2024 4:53pm
Danwilderspin
Think I am going to leave it as while it runs nice I have only just spotted a 50k mile gap in the service history. Have been told it was serviced locally but no evidence of this… I’m guessing this would put most people off too Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #696827 24th Jul 2024 4:54pm
