![]() | Home > Technical (L405) > Check coolant level |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
Is the coolant level low?
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
The water drains would worry me more , check on here about this. overfinch modified |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 214 ![]() ![]() ![]() |
Personally I would have run a mile at the first mention of 'blocked sunroof drains' let alone having the 'check coolant' light as well. _______________________________________________
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 ![]() ![]() ![]() |
Sunroof drains is a fairly easy, if not quick, fix and not a lot of money if you can do it yourself.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
As the miles creep up and the rubber gets older, they can use a little bit of coolant, especially as the SDV8 has about 15,000 miles of pipework. 2015 Range Rover Autobiography 4.4 SDV8 |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 ![]() ![]() ![]() |
Think I am going to leave it as while it runs nice I have only just spotted a 50k mile gap in the service history. Have been told it was serviced locally but no evidence of this… I’m guessing this would put most people off too Current stable:
