Home > Maintenance & Mods (L322) > ABS Sensor Problem - TD6
stuart_2006
TD6, VIN 6A202xxx
Hi. Had a fault come up on the dash - HDC inoperative and suspension lowered. GAPIId tool reported error 0x21 - front left ABS sensor open circuit. Ordered a new sensor SSF500011 (although the one delivered was labelled SSF500011R).
Managed to get the old sensor out and fitted new. Fault has now cleared, but it seems that the ABS is trying to lock the brakes - have hardly managed to get off the drive.
The reluctor ring in the hub looks OK - rotated the hub while peering down the sensor hole with a torch and the ring looks intact and clean. I don't think the GAPIId tool gives lives values for the ABS sensors.
Unplugged new sensor and original problem returns as expected, and brakes not locked.
Anyone experienced this before? Any ideas?
Many thanks,
Stuart
Post #696441 18th Jul 2024 1:36pm
mjdronfield
Is the speedo working correctly? I had similar and it was traction control coming on as it thought 3 wheels were spinning, as no speed feed from one wheel, though as you say, rear left feeds the speedo…..
If you keep trying to accelerate does it stay the same or does it cut engine power?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #696445 18th Jul 2024 3:21pm
GRANGEROVER
Germany
Is the colour of your new sensor plug the same as the one on your car? I had the same problem with a new sensor. There seems to be a difference even though the plug is compatible.
I bought a new blue Bosch sensor for my TD6 which fixed the problem.
Post #696475 19th Jul 2024 8:00am
stuart_2006
GRANGEROVER - The new sensor plug is a different colour - one is blue and the other green. Do you still have a part number for the Bosch one you got? Have wondered about getting a LR original one but it is expensive if it also doesn't work.
Post #696482 19th Jul 2024 9:45am
stuart_2006
Haven't gone far or fast enough to check to be honest - single track road out the front and don't want to fnd that the brakes lock up completely or something. As it's a front sensor that is playing up, I assume the speedo still works if fed from a rear sensor.
Post #696483 19th Jul 2024 9:47am
dingg1
Measure the resistance of the working abs sensor against the new one to check its the correct one.
Different models and different years have different sensors, pain in the arse when someone confirms that it's the right one and actually isn't.
Ask me how I know 😂😂
Post #696491 19th Jul 2024 11:56am
GRANGEROVER
Germany
If you have a green sensor it will definitely not work. I tried that two times and I had the exact problem that the car wouldn't drive.
The Bosch sensor has the number BOSCH 0 986 594 663.
Post #696494 19th Jul 2024 12:56pm
stuart_2006
The moral of the story is, if you've got a TD6, ignore the supplier online parts diagrams that say that your VIN needs a SSF500011 sensor, it needs to be a SSF000011 one. The latter should have a blue connector which matches the blue connector on the car.
So I have two shiny almost-never-used SSF500011 sensors up for grabs, if anyone is interested!
Post #697164 30th Jul 2024 8:43pm
