Home > Maintenance & Mods (L322) > ABS Sensor Problem - TD6 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
Is the speedo working correctly? I had similar and it was traction control coming on as it thought 3 wheels were spinning, as no speed feed from one wheel, though as you say, rear left feeds the speedo…..
18th Jul 2024 2:21pm |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 34 |
Is the colour of your new sensor plug the same as the one on your car? I had the same problem with a new sensor. There seems to be a difference even though the plug is compatible.
19th Jul 2024 7:00am |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 |
GRANGEROVER - The new sensor plug is a different colour - one is blue and the other green. Do you still have a part number for the Bosch one you got? Have wondered about getting a LR original one but it is expensive if it also doesn't work. |
19th Jul 2024 8:45am |
Haven't gone far or fast enough to check to be honest - single track road out the front and don't want to fnd that the brakes lock up completely or something. As it's a front sensor that is playing up, I assume the speedo still works if fed from a rear sensor. |
19th Jul 2024 8:47am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Measure the resistance of the working abs sensor against the new one to check its the correct one.
19th Jul 2024 10:56am |
If you have a green sensor it will definitely not work. I tried that two times and I had the exact problem that the car wouldn't drive.
19th Jul 2024 11:56am |
The moral of the story is, if you've got a TD6, ignore the supplier online parts diagrams that say that your VIN needs a SSF500011 sensor, it needs to be a SSF000011 one. The latter should have a blue connector which matches the blue connector on the car.
30th Jul 2024 7:43pm |
