![]() | Home > Maintenance & Mods (L322) > wheel bearing sound |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 143 ![]() ![]() ![]() |
Front diff maybe low on oil??
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 94 ![]() ![]() |
I also have Grabbers all round and it sounds as if a bearing noise is NSR.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 282 ![]() ![]() ![]() |
front/rear diffs have had oil change as well as transfer box in the last 2 months no change, as for tyre noise i don’t know 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2377 ![]() ![]() ![]() |
Mine's FR wheel bearing noise with AT tyres was caused by 2 brake pipes vibrating together not far from the master cylinder. The spacer clip had detached at 1 end. |
Now that is something you wouldn’t think of,I will have a check when I check the diff oil 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
I had a workshop replace the wheel bearing after a failed attempt myself but the noise persisted, then eventually finding the pipes when seaching for anything that might cause the noise. |
So did your noise sound like a worn wheel bearing then ? 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
