Home > Maintenance & Mods (L322) > wheel bearing sound
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
wheel bearing sound
hi guys
right ive had for awhile now what sounds like a wheel bearing noise (front of side sounds like) how ever
past its mot . i have tried swapping tyres around no change running grabber at3 i have even replaced the wheel bearing still there the noise is speed related but im at a total loss if anybody has any suggestion's or has had this and knows the problem please shout out .
thanks will
Post #695893 10th Jul 2024 11:02am
Scouse Exile
Front diff maybe low on oil??
J
Post #695901 10th Jul 2024 12:39pm
toby1
I also have Grabbers all round and it sounds as if a bearing noise is NSR.
I have nothing to compare against so I am living with it until the MoT in December.
Post #695906 10th Jul 2024 1:29pm
will308f
front/rear diffs have had oil change as well as transfer box in the last 2 months no change, as for tyre noise i don’t know
Post #695910 10th Jul 2024 2:35pm
GraemeS
Mine's FR wheel bearing noise with AT tyres was caused by 2 brake pipes vibrating together not far from the master cylinder. The spacer clip had detached at 1 end.
Post #695944 10th Jul 2024 8:40pm
will308f
Now that is something you wouldn’t think of,I will have a check when I check the diff oil
Post #695948 10th Jul 2024 9:23pm
GraemeS
I had a workshop replace the wheel bearing after a failed attempt myself but the noise persisted, then eventually finding the pipes when seaching for anything that might cause the noise.
Post #695951 11th Jul 2024 12:45am
will308f
So did your noise sound like a worn wheel bearing then ?
Post #695959 11th Jul 2024 7:39am
