Home > Maintenance & Mods (L322) > wheel bearing sound |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 147 |
Front diff maybe low on oil??
10th Jul 2024 1:39pm |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 96 |
I also have Grabbers all round and it sounds as if a bearing noise is NSR.
10th Jul 2024 2:29pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 288 |
front/rear diffs have had oil change as well as transfer box in the last 2 months no change, as for tyre noise i don’t know 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
10th Jul 2024 3:35pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2382 |
Mine's FR wheel bearing noise with AT tyres was caused by 2 brake pipes vibrating together not far from the master cylinder. The spacer clip had detached at 1 end. |
10th Jul 2024 9:40pm |
Now that is something you wouldn’t think of,I will have a check when I check the diff oil 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
10th Jul 2024 10:23pm |
I had a workshop replace the wheel bearing after a failed attempt myself but the noise persisted, then eventually finding the pipes when seaching for anything that might cause the noise. |
11th Jul 2024 1:45am |
So did your noise sound like a worn wheel bearing then ? 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
11th Jul 2024 8:39am |
