![]() | Home > Technical (L405) > Restricted performance, anyone had similar...? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8500 ![]() ![]() ![]() |
I was darn sooth for a couple of days, been driving for 10miles on minor "A" roads when "restricted performance" came up on the dash, no bong at all but there was no power, was coming to a slight incline so managed to pull off the road.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35593 ![]() ![]() |
new battery , maybe loose connection? ... - .- -.
Checked and double checked Stan, I instantly thought voltage but both batteries are perfect and correctly fitted...
you're probably right Pete but its frustrating not knowing the cause..
Thanks Stan,
Thanks for the thoughts, you could be right, I put it on here to see if someone had had similar but it appears not. I don't think I'm going to be able to search for it unless it does it again and stays like it..!!
Here we are, 4 months and several thousand miles of fault free motoring and it does something similar...
could be,
Thanks Stan, I was thinking something similar, I gave it a full throttle test on the way home and it was fine so I don't think it's a split or a leak.... (you forget how rapid these things are when given the beans!!)
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1450 ![]() ![]() |
I think you need to have that IIDtool with you all the time and read the codes as soon as the error pops up.
Thanks for the input and taking the time to type all that, the IID lives in the car and was used immediately, any fault code will stay on the list until it's cleared...
Could it be a split which opens only on negative plenum pressure rather than under boost?
Thanks again, I've just been chatting with a mate who used to work for JLR as an engineer.
