Home > Technical (L405) > Restricted performance, anyone had similar...? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
I was darn sooth for a couple of days, been driving for 10miles on minor "A" roads when "restricted performance" came up on the dash, no bong at all but there was no power, was coming to a slight incline so managed to pull off the road.
10th Jun 2024 11:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35433 |
new battery , maybe loose connection? ... - .- -.
10th Jun 2024 11:49am |
Checked and double checked Stan, I instantly thought voltage but both batteries are perfect and correctly fitted...
10th Jun 2024 12:28pm |
you're probably right Pete but its frustrating not knowing the cause..
10th Jun 2024 12:45pm |
Thanks Stan,
10th Jun 2024 1:06pm |
Thanks for the thoughts, you could be right, I put it on here to see if someone had had similar but it appears not. I don't think I'm going to be able to search for it unless it does it again and stays like it..!!
11th Jun 2024 5:16pm |
Here we are, 4 months and several thousand miles of fault free motoring and it does something similar...
18th Oct 2024 9:15am |
could be,
18th Oct 2024 10:11am |
Thanks Stan, I was thinking something similar, I gave it a full throttle test on the way home and it was fine so I don't think it's a split or a leak.... (you forget how rapid these things are when given the beans!!)
18th Oct 2024 10:25am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1394 |
I think you need to have that IIDtool with you all the time and read the codes as soon as the error pops up.
18th Oct 2024 6:02pm |
Thanks for the input and taking the time to type all that, the IID lives in the car and was used immediately, any fault code will stay on the list until it's cleared...
18th Oct 2024 7:17pm |
Could it be a split which opens only on negative plenum pressure rather than under boost?
18th Oct 2024 8:00pm |
Thanks again, I've just been chatting with a mate who used to work for JLR as an engineer.
18th Oct 2024 8:59pm |
