Home > Technical (L322) > Strange speed restriction problem
GJOB
2005 Range Rover Vogue SE Td6 Java Black
I'm currently struggling with an intermittent speed restriction problem, I've had a search around but couldn't find any posts with the same issue.
When driving and accelerating the speed just stops increasing. Pressing harder on the peddle causes the gearbox to change down and rev higher but the speed refuses to increase.
It happens at various speeds but generally around the 60-75 mph mark. Acceleration through the gears is fine and revs are fine. There are no fault codes showing, the dealer has experienced it at 50mph when testing it after replacing a selection of filters including the fuel filter.
The best way to describe it would be as if a speed restrictor was applied although sometimes if you back off it will let you proceed beyond that speed and continue normally.
Without any codes showing I thought someone on here may have experienced this before, any help would be greatly appreciated.
TIA
S
Post #76075 13th Aug 2011 3:34pm
GJOB
I take it that's a no then Crying or Very sad
Post #76368 15th Aug 2011 8:41pm
mzplcg
Sounds like fuel starvation to me. The bit about lifting off and then being able to drive through it suggests the brief lift allows fuel pressure to build back up. Might be worth getting the high pressure pump tested, also the lift pump.
Dom.
Post #76381 15th Aug 2011 9:21pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
you have a secondary fuel pump on the td6, these seem to go first. 2004 black Vogue TD6
Post #76461 16th Aug 2011 11:53am
GJOB
Thanks chaps, I'll get that checked out.
Post #76520 16th Aug 2011 8:29pm
GJOB
Replacement pump ordered, hopefully going to be sorted next week. Th warranty is picking up the bill, phew!!
Post #76809 19th Aug 2011 11:39pm
GJOB
Got it back, all sorted but it had started bloody working again before it went in.
Now I can still hear an intermittent noise sounds like a compressor or pump making short intermittent noises, I thought it was the old pump but since it's still there I'm worried it might be another element of the fuelling system - what else is on the front off-side of the car? the HP pump?
On a positive note the FBH is fully operational now that the software has been downloaded.
Just the sticky clutch on the cooling on fan and the newly discovered drivers wing mirror is only adjusting on one axis.
It's never ending, I'm starting to miss my P38 Shocked
Post #81074 13th Sep 2011 9:24pm
brumster
United Kingdom 2006 Range Rover SE TDV8 Buckingham Blue
Loved my p38 but I wish I'd chopped it in earlier in favour of an L322. Stick with it. Definitely worth the hassle even with the teething probs!
Post #81075 13th Sep 2011 9:39pm
i agree with brumster, why have a boring car that works first time and nothing goes wrong with it, better to have a fullfat and battle your wits against it... Very Happy
Post #81107 14th Sep 2011 7:17am
bozmandb9
It it's anything like the 530d (same engine), then after one pump goes, the other one will too, since it's been overworked to compensate for the failing pump.
I had a 530d, and after replacing both of the pumps it was like a new car! Range Rover-less at the moment - Pining!
Post #81110 14th Sep 2011 7:25am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I'd suggest it's also worth checking the MAF. That can cause these sorts of problems.
Post #81397 15th Sep 2011 9:38am
GJOB
Thanks chaps, my neighbour cowers when he see me these days, I just give him the keys, his fault for being a LR service manager Laughing
Thank god for warranties Thumbs Up
Now for some searching to sort the other niggles unless any of you kind chaps can point to in the right direction:
1. Wing mirror off side won't go up and down
2. fan kicks in when engines getting hot but doesn't disengage for ages even when back on to open roads
If I get these sorted before xmas it's drinks on me*
*1 per person, T&C's apply and you might have to do a little dance Thumbs Up
Post #81578 15th Sep 2011 7:37pm
