Home > Technical (L322) > Strange speed restriction problem |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 |
I take it that's a no then |
15th Aug 2011 8:41pm |
Sounds like fuel starvation to me. The bit about lifting off and then being able to drive through it suggests the brief lift allows fuel pressure to build back up. Might be worth getting the high pressure pump tested, also the lift pump.
15th Aug 2011 9:21pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
you have a secondary fuel pump on the td6, these seem to go first. 2004 black Vogue TD6 |
16th Aug 2011 11:53am |
Thanks chaps, I'll get that checked out. |
16th Aug 2011 8:29pm |
Replacement pump ordered, hopefully going to be sorted next week. Th warranty is picking up the bill, phew!! |
19th Aug 2011 11:39pm |
Got it back, all sorted but it had started bloody working again before it went in.
13th Sep 2011 9:24pm |
brumster Member Since: 23 May 2011 Location: Chislehurst Posts: 41 |
Loved my p38 but I wish I'd chopped it in earlier in favour of an L322. Stick with it. Definitely worth the hassle even with the teething probs! |
13th Sep 2011 9:39pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35268 |
i agree with brumster, why have a boring car that works first time and nothing goes wrong with it, better to have a fullfat and battle your wits against it... |
14th Sep 2011 7:17am |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
It it's anything like the 530d (same engine), then after one pump goes, the other one will too, since it's been overworked to compensate for the failing pump.
14th Sep 2011 7:25am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
I'd suggest it's also worth checking the MAF. That can cause these sorts of problems. |
15th Sep 2011 9:38am |
Thanks chaps, my neighbour cowers when he see me these days, I just give him the keys, his fault for being a LR service manager
15th Sep 2011 7:37pm |
