Home > Maintenance & Mods (L322) > Where to buy bonnet and tailgate lettering?
RangeRov
Sweden
Hi all,
Preparing for a tailgate repaint and full polish of my 2009 RR and trying to find new none original lettering in titanium as the rear letters will be removed.
Any advice of where you've been successful or know where others bought the letters? Been searching on the forum and found the below 4 options.
PowerfulUK don't sell them anymore.
SuperTweaks don't allow me to pay with card.
AliExpress has quite wider offering which makes it hard to tell what's good and bad.
Ebay.co.uk similar to AliExpress.
Need some clear pointers to maybe a specific ebay account if anyone has advice Bow down
 2009 L322 4.2 Supercharged
Post #693459 27th May 2024 7:53pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I bought these:
https://www.ebay.co.uk/itm/256477759542
Decent price, all good really.
Post #693470 28th May 2024 7:46am
RangeRov
Sweden
Do they make a distinction between bonnet and the tailgate? I understand the bonnet letters are curved.
Thanks for the advice! Very Happy 2009 L322 4.2 Supercharged
Post #693471 28th May 2024 8:27am
ballast
Nope, they were both the same - I replaced both bonnet and tailgate.
Post #693472 28th May 2024 8:43am
toby1
ballast wrote:
I bought these:
I bought the same. Perfect match for mine though the template was 5mm too close to each letter. See my RR thread for a picture.
Post #693475 28th May 2024 9:39am
gt40
South Africa 2011 Range Rover Vogue SE TDV8 Zambezi Silver
The bonnet and tailgate have a different curve which means they should be different hence the different part numbers. It is very slight so I guess you can get away with it (if you dont look too closely) but when you look at the letters close up and side by side the difference is obvious.
Post #693516 29th May 2024 12:16am
PK17
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Corris Grey
You could try here...
https://www.lrparts.net/vehicle/range-rove...g.html?p=2
Post #693529 29th May 2024 8:30am
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Is it that the letters you've got are still ok and only being removed due to tailgate repaint?
If that's the case, couldn't you just have them removed, then renew the 3M tape on the back of them and re-attach?
Post #693534 29th May 2024 9:08am
Scouse Exile
I think Batfink has the right idea - exactly what I did with about £20 of materials (paint and tape) - looks correct and obviously reuses the original parts. What’s not to like Very Happy
Jon
Post #693643 30th May 2024 4:37pm
RangeRov
Sweden
Yes, the letters are OK. The guy helping me said there's a risk they will brake when he will remove them, I don't think he have done it before.
As I'll do the repaint first, I can ask him to be careful and buy the lettering removal kit and template from powerfulUK for him.
Are there any particular 3M adhesive tape that are used? 2009 L322 4.2 Supercharged
Post #693649 30th May 2024 6:10pm
batfink
Get him to use a bit of heat (hair dryer or hot water) on them to loosen the glue, then use some dental floss or fishing string behind them to remove them.
Lots of info if you have a look at YouTube
Post #693651 30th May 2024 6:31pm
Scouse Exile
So long as he doesn’t have hands like an ape then there’s not really much chance of breaking them, as already said a little nylon wire or whatever will ensure they come off without much fuss.
I seem to recall using this stuff to reattach;
https://amzn.eu/d/5ZKAKBh
You just have to get rid of all the old tape in the recess of the letters but it’s better than spending £50+ on new ones. You can even get the correct paint mixed up if you can be bothered but so long as you go with a reasonable matching paint they’ll be fine.
It’s fiddly and time consuming but I’d say worth it.
J
Post #693661 30th May 2024 7:58pm
RangeRov
Sweden
Thanks!
Did you recall using 6.35mm or 12.7mm? 2009 L322 4.2 Supercharged
Post #694363 13th Jun 2024 11:50am
Scouse Exile
Hi just double checked my Amazon order from 2022 and it was 6.35mm
It fits quite well into the recess on the reverse side of the letters - bit fiddly as you'll need a sharp knife and cut a few small bits for the E and so on but it worked fine and so far they are still stuck to the bonnet - the most important thing to do is to make sure that the bonnet is squeaky clean before trying to attach.
J
Post #694368 13th Jun 2024 12:44pm
RangeRov
Sweden
The tailgate rust is now gone and it looks great Very Happy So tomorrow I'll use the tape to get the letters back on the tailgate before the car is sent in for polish and ceramic treatment.
Any advice on how to prepare the surface of the letters and the tailgate before taping it back? I'm removing the old glue thinking if I should clean the surface of the letters with all purpose cleaner or some alcohol or if water to remove the dust/dirt is enough?
Post #701014 28th Sep 2024 2:16pm
