Home > Maintenance & Mods (L322) > Where to buy bonnet and tailgate lettering? |
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 46 |
I bought these:
28th May 2024 8:46am |
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 41 |
Do they make a distinction between bonnet and the tailgate? I understand the bonnet letters are curved.
28th May 2024 9:27am |
Nope, they were both the same - I replaced both bonnet and tailgate. |
28th May 2024 9:43am |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 96 |
I bought the same. Perfect match for mine though the template was 5mm too close to each letter. See my RR thread for a picture. |
28th May 2024 10:39am |
gt40 Member Since: 30 Jan 2013 Location: Cape Town Posts: 25 |
The bonnet and tailgate have a different curve which means they should be different hence the different part numbers. It is very slight so I guess you can get away with it (if you dont look too closely) but when you look at the letters close up and side by side the difference is obvious. |
29th May 2024 1:16am |
PK17 Member Since: 23 Apr 2020 Location: manchester Posts: 9 |
You could try here...
29th May 2024 9:30am |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 182 |
Is it that the letters you've got are still ok and only being removed due to tailgate repaint?
29th May 2024 10:08am |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 147 |
I think Batfink has the right idea - exactly what I did with about £20 of materials (paint and tape) - looks correct and obviously reuses the original parts. What’s not to like
30th May 2024 5:37pm |
Yes, the letters are OK. The guy helping me said there's a risk they will brake when he will remove them, I don't think he have done it before.
30th May 2024 7:10pm |
Get him to use a bit of heat (hair dryer or hot water) on them to loosen the glue, then use some dental floss or fishing string behind them to remove them.
30th May 2024 7:31pm |
So long as he doesn’t have hands like an ape then there’s not really much chance of breaking them, as already said a little nylon wire or whatever will ensure they come off without much fuss.
30th May 2024 8:58pm |
Thanks!
13th Jun 2024 12:50pm |
Hi just double checked my Amazon order from 2022 and it was 6.35mm
13th Jun 2024 1:44pm |
