Home > Maintenance & Mods (L322) > Seat belts high adjuster cover fix
fatu
Czech Republic 2012 Range Rover Vogue TDV8 Sumatra Black
Hi, is there anyway to fix it, attached photo? Easy way possibly, I looked carefully it does not look broken, I might be wrong. I just want to put it to its place. Adjustment is working fine. Thanks Range Rover 2012 4.4 TDV8 - current
Range Rover 2008 3.6 TDV8 - previous
Range Rover 2004 3.0 TDV6 - previous
Post #693320 25th May 2024 8:47pm
fatu
Sorry didn’t upload in the first post.
Post #693321 25th May 2024 8:48pm
fatu
And realized that typo on the subject and put it on the wrong channel… this is l322 4.4 tdv8. Sorry for that. Range Rover 2012 4.4 TDV8 - current
Post #693324 25th May 2024 8:53pm
Shaun_
This happened to mine too. In my case I heard something tiny (maybe a spring or small plastic piece?) fall off and drop to the bottom of the pillar.
However, with a bit of patience I was able to gently manoeuvre the top cover piece into place and it felt as if it gently popped back into position. If I were to push it backwards I think it would quite easily do what yours has done again but as I never adjust it I'm happier to live with it (it looks perfect and stays in position) than to dismantle the whole pillar cover assembly and risk the inevitable damage to clips etc. that almost always result in rattles.
Good luck anyway. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #693446 27th May 2024 4:53pm
SimonL322
Canada 2012 Range Rover Supercharged 5.0 SC V8 Orkney Grey
I also have the same issue with mine
Post #693448 27th May 2024 5:19pm
