Home > Technical (L405) > L405 SDV8 Oil in the plenum etc. Help!
19pontiac87
D3Jon wrote:
Thanks Kevin, Thumbs Up
Will do a search for that post, as I'd love to know how incorrect oil filter installation leads to oil getting into the intake system? I'm speculating it's via a breather if the top of the engine is filling up with oil?
I wonder how many people have shed out an awful lot of money on unnecessary repairs, when the fix may be as simple as the oil filter not being seated correctly on its post?
Jon
Don't suppose you ever found the post did you Jon?
Looks like I'm dealing with this same issue, I just don't understand how.
Post #698892 27th Aug 2024 8:16am
GraemeS
When the drain hole isn't plugged, lots of oil escapes flooding the breather oil extraction chamber causing oil to be passed to the turbo inlet tract.
An unsealed hole also reduces oil pressure to all the bearings etc and empties the filter chamber when the engine is stopped which then has to be filled once the engine starts, so it's imperative that the hole is plugged.
Post #698900 27th Aug 2024 9:38am
19pontiac87
Thank you GraemeS, that makes perfect sense and was pretty much along the lines of what I was thinking.
Post #698930 27th Aug 2024 2:17pm
D3Jon
Thanks Graeme, pretty much what I thought must be happening with oil pooling high up in the engine and making it's way out through a breather.
19pontiac87 - I never did find the post Kevin referred to, but I think Graeme has covered it off above Thumbs Up
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #699235 1st Sep 2024 10:38am
