![]() | Home > Technical (L405) > L405 SDV8 Oil in the plenum etc. Help! |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
When the drain hole isn't plugged, lots of oil escapes flooding the breather oil extraction chamber causing oil to be passed to the turbo inlet tract.
19pontiac87 Member Since: 23 Aug 2024 Location: Northallerton Posts: 2 ![]() ![]() |
Thank you GraemeS, that makes perfect sense and was pretty much along the lines of what I was thinking. |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
Thanks Graeme, pretty much what I thought must be happening with oil pooling high up in the engine and making it's way out through a breather.
