![]() | Home > In Car Electronics (L322) > Bluetooth upgrade |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
There's a write up in the wiki on here detailing how to do it. |
philcorsa Member Since: 11 Apr 2016 Location: vienne Posts: 43 ![]() ![]() ![]() |
i've seen it but sorry i don't understand anything, may be i'm stupid ! |
well first many thanks to Adrian Wiggins for is wonderful help.
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
In case anyone else sees this who has the connector like above.
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
I was lucky enough to spot a New Old Stock late Bluetooth Module on ebay just after Christmas (Part No. AH42 10F845 AA ) for less than many were trying to sell S/H units & have just installed it using the Wiki link as a guide.
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
just installed the later module on my rr ,thanks wiggs for the info ,i did mine a little different i got a new unit and i also got the multi plug with the 2 wires coming out of it ,i got a 2pin lead male and female spiced into the loom and soldered the 2 pin female length into the loom and the male onto the tails coming out of the multi plug i can now unplug it and keep the multi plug that goes into the module or i can use the old nokia if i need to swap new module to another rr |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
whare is this part located RR 2005 4.4 petrol
It's in the boot, left hand side rear , behind the pull out panel where the Sat Nav & Audio amp is located Paul,
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Does the later module have expanded functionality? I see most ads post the module with "Central locking unit" as description. 2007 L322 3.6 TDV8 Stornoway |
The later part (part no. as above) gives you access to your mobile phones phonebook via Bluetooth & will show all phone nos if you have multiple nos for the same person.
Thanks Paul,
jncunliffe Member Since: 01 Mar 2013 Location: Dorset Posts: 8 ![]() ![]() |
Has anyone tried to upgrade from the old Nokia style BT unit, mines on a L322 MY07, to the Jaguar version of the 'new' BT module, part number 7G9N-10D893-AG....? It looks identical to the LR part but looks can be deceiving...!
petercole237292 Member Since: 04 Sep 2020 Location: west sussex Posts: 1 ![]() ![]() ![]() |
22Auto Member Since: 05 Jul 2023 Location: West Midlands Posts: 3 ![]() ![]() ![]() |
Hi all, I have a 2005MY TD6 with the Denso touch screen system and originally the Nokia Bluetooth module. Unfortunately the module failed, (some component on the circuit board burnt out), so I've tried to upgrade and fit the later style module AH42 10F845 AA from ebay, by following the connection info detailed in the wiki info, to power it up.
