Home > In Car Electronics (L322) > Bluetooth upgrade
philcorsa
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Bluetooth upgrade
Hi everybody
is there anybody who make an upgrde from the old nokia BT module
to the later one
the optical fiber plug is the same but not the electric one
thanks for your help !
[/img] RR L322 4.4 TDV8 Vogue
RR L322 3.6TDV8 Vogue
Disco TD5 HSE
RR P38 4.6 HSE v8 GPL
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #458503 25th Nov 2017 2:40pm
Paul thornton
There's a write up in the wiki on here detailing how to do it.
Post #458504 25th Nov 2017 3:04pm
philcorsa
i've seen it but sorry i don't understand anything, may be i'm stupid ! Wink RR L322 4.4 TDV8 Vogue
Disco TD5 HSE
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #458507 25th Nov 2017 3:17pm
philcorsa
well first many thanks to Adrian Wiggins for is wonderful help.
so you could change easily your old BT Nokia module by a new one (have a look on ebay about 150£ second hand), ask the seller to keep the plug if possible
you have only to connect positive (purple on the new one) and negative (black on the new one) to the new module (power), and the rest is done through the fibre optic
for connect the power have a look at Adrian publication on Wiki / electronics/ replace a bluetooth module with a 2010 unit.
from the old module : positive pin 16, negative pin 33 or 34 RR L322 4.4 TDV8 Vogue
Disco TD5 HSE
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #459332 2nd Dec 2017 5:32pm
gizze
In case anyone else sees this who has the connector like above.
If you take out the wires from the connectors, use a pin to push the 'catch' down and pull the wire out, you can transfer the two wires needed from your old connector.
Wire 33 or 34 is positive on the old connector and that goes to pin 15 on the new connector.
Wire 16 on the old connector is ground and that goes to pin 31 on the new connector.
Slide those into the connector you have making sure the 'catch' is facing the hole if you need to get it out again and you are away. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #461901 23rd Dec 2017 12:56pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I was lucky enough to spot a New Old Stock late Bluetooth Module on ebay just after Christmas (Part No. AH42 10F845 AA ) for less than many were trying to sell S/H units & have just installed it using the Wiki link as a guide.
I was very fortunate that I had an old BMW sound system connector similar to the 1 used with the newer BT modules, so only had to pull the relevant 2 wires / connectors out of the old plug & insert them into the new plug & I was sorted.
I couldn't spot any easy way of fastening the new module in place of the old one - as the shape is different & the connector positions don't suit. So I tie-wrapped the new one in place under the Navigation DVD player & sealed up & fastened the old connector out of the way.
I was surprised the complete job only took 30 mins & I now have access to my phone book & importantly for me where contacts have multiple phone nos (Mobiles, land lines etc), I have access to them all !
I did have 1 shock though. After turning on the ignition after the installation & starting the engine, the message center made a few bongs & told me I only had limited gears & wouldn't let me out of Park Crying or Very sad .
I wondered what I'd messed up, but then just turned everything off & re-started the engine & the fault had gone, everything seems OK Very Happy
NB : As far as I could make out from the many forum posts discussing this mod, there are 2 different Part Nos which are suitable : AH42 10F845 AA (which I used) & 8H42 10F845 AA.
If anyone knows different please correct me. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #464209 11th Jan 2018 8:52pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
just installed the later module on my rr ,thanks wiggs for the info ,i did mine a little different i got a new unit and i also got the multi plug with the 2 wires coming out of it ,i got a 2pin lead male and female spiced into the loom and soldered the 2 pin female length into the loom and the male onto the tails coming out of the multi plug i can now unplug it and keep the multi plug that goes into the module or i can use the old nokia if i need to swap new module to another rr
Post #483488 15th Jul 2018 12:31pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
whare is this part located RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #483574 16th Jul 2018 2:45pm
Pawl
It's in the boot, left hand side rear , behind the pull out panel where the Sat Nav & Audio amp is located Paul,
Post #483582 16th Jul 2018 4:42pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Does the later module have expanded functionality? I see most ads post the module with "Central locking unit" as description. 2007 L322 3.6 TDV8 Stornoway
Post #494474 2nd Nov 2018 10:39pm
Pawl
The later part (part no. as above) gives you access to your mobile phones phonebook via Bluetooth & will show all phone nos if you have multiple nos for the same person.
It won't deal with text messages though. Paul,
Post #494477 2nd Nov 2018 11:26pm
S.Hafsmo
Thanks Paul,
I'll give it a shot, then.
The old one worked just fine until I opened it to check for water ingress (slight evidence of such on the connector).
By the way, if the BT module fails, it's no problem at all to unclip the individual fiber optic cable from the connector and just move it to the next module in line. I've now removed both the TMC and BT without issued. Though the BT is currently replaced by a mObridge DAB unit. 2007 L322 3.6 TDV8 Stornoway
Post #494483 3rd Nov 2018 5:44am
jncunliffe
2007 Range Rover Vogue SE TDV8 Stornoway Grey
Has anyone tried to upgrade from the old Nokia style BT unit, mines on a L322 MY07, to the Jaguar version of the 'new' BT module, part number 7G9N-10D893-AG....? It looks identical to the LR part but looks can be deceiving...!
Cheers,
Jon
Post #503581 1st Feb 2019 3:11pm
petercole237292
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Buckingham Blue
has anyone actually got a link to this ?
Post #566278 4th Sep 2020 2:30pm
22Auto
United Kingdom 2005 Range Rover HSE Td6 Giverny Green
Hi all, I have a 2005MY TD6 with the Denso touch screen system and originally the Nokia Bluetooth module. Unfortunately the module failed, (some component on the circuit board burnt out), so I've tried to upgrade and fit the later style module AH42 10F845 AA from ebay, by following the connection info detailed in the wiki info, to power it up.
Unfortunately when selecting the phone screen I just get 'No phone fitted', and my android phone cannot find any LandRover bluetooth signal. The unit must be powering up OK as other functions such as radio/Nav etc still function when it is in the MOST circuit.
Apart from the cause being me fitting a faulty module, I just wondered if anyone had come across this issue when trying to upgrade or had any suggestions I could try.
Thank you.
Post #692921 18th May 2024 10:02pm
