Home > Technical (L405) > Deployable side steps switched off |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
i'm sure theres something in these threads that will solve your problem,
19th May 2024 2:24pm |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 |
I have looked through a lot of those but nothing relates to a 2018, only thing of interest was the tr2 knob was referred too... What's that? 2018 L405 Autobiograpghy
19th May 2024 2:49pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
That's the Terrain Response dial - next to the gear selector - it should be down - when you press it, it pops up.
19th May 2024 3:32pm |
Here's the manual - |
19th May 2024 3:37pm |
Oh right of course... mines down... Mine is a 2018 so I dont have the button by my knee, on my main display I can turn them off/on set roof access or off road mode, problem I have is they are switched off and when I press on, it goes off after 2 seconds and wont stay on, no fault codes logged.
19th May 2024 4:02pm |
ECU unreachable sounds like either a faulty steps ECU, a loose connector or a broken wire in a loom somewhere.... I wouldn't really know where to start |
19th May 2024 4:26pm |
I've not watched it, but this guy has done an installation video, so I guess that will show you where the wiring goes, so that you can at least check the connections ?
19th May 2024 4:30pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
He has the early model 2016 onwards, which are different the modules are on the left side of the spare wheel as opposed to the right side in the early ones, and there is also no control button on the lower dash
19th May 2024 6:30pm |
Fuse was ok, I spoke to the dealer as it happened when they had it in for a service, they are collecting it and taking it back in to sort it as it's their fault.
20th May 2024 10:06pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 584 |
Almost certainly not relevant to this situation but FWIW
21st May 2024 9:27am |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 42 |
Just a thought. Did the dealers do any kind of software update or reset ( maybe had the key security update ) if so if they reset the ccf files. It knocks off the side steps. If so easy fix to switch back on again. Hopefully dealer will help and sort. |
27th May 2024 10:34am |
It went back to the dealer and when they sorted the steering column calibration they lost the connection to the side steps ECU. All sorted now after they turned it back on. They even put some fuel in the tank for me.. 2018 L405 Autobiograpghy
27th May 2024 10:39am |
