Home > Technical (L322) > Do you know where this pipe should be attached |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 |
The left hand hard pipe looks like the front diff breather and the right hand pipe attaches to the small outlet on the rear of the air filter housing. |
16th May 2024 7:25am |
sjstukins Member Since: 15 May 2024 Location: Essex Posts: 3 |
Thank you for the info but I do not have any fixings on the air box for this to attach to so if there are any other ideas it would be much appreciated |
18th May 2024 1:59pm |
I have a 2008, 2009 and 2010 TDV8 3.6 and all 3 have that pipe which is arrowed in my attached photo.
18th May 2024 2:20pm |
Thank you for the picture didn’t think of looking on the lid much appreciated for your help have you ever had issues with turbo actuator b sticking and any solutions many thanks again for your help |
18th May 2024 2:43pm |
I have had the sticking turbo actuator. I managed to access it from under the car through a very small gap. Its been a few years since I last did it but used a length of wire with an appropriately shaped bend at the end and sprayed WD40 with a extra length tube to get the spray close to the actuator.
18th May 2024 2:54pm |
