Home > Technical (L322) > Do you know where this pipe should be attached
sjstukins
Hi
I have an issue with n/s turbo actuator sticking so I removed the air filter box to gain more access in doing this I found a hose off but cannot work out where it should connect to .Between the row inlet pipes there is a bent over plastic pipe but the bore seems too small for this pipe to connect to
I have attached a picture with yellow lines pointing to the two pipes. The car is a 2009 3.6 TDV8 any help would be appreciated
Post #692699 15th May 2024 11:31am
gt40
South Africa 2011 Range Rover Vogue SE TDV8 Zambezi Silver
The left hand hard pipe looks like the front diff breather and the right hand pipe attaches to the small outlet on the rear of the air filter housing.
Post #692754 16th May 2024 7:25am
sjstukins
Thank you for the info but I do not have any fixings on the air box for this to attach to so if there are any other ideas it would be much appreciated
Post #692900 18th May 2024 1:59pm
gt40
I have a 2008, 2009 and 2010 TDV8 3.6 and all 3 have that pipe which is arrowed in my attached photo.
[/img]
Post #692903 18th May 2024 2:20pm
sjstukins
Thank you for the picture didn’t think of looking on the lid much appreciated for your help have you ever had issues with turbo actuator b sticking and any solutions many thanks again for your help
Post #692904 18th May 2024 2:43pm
gt40
I have had the sticking turbo actuator. I managed to access it from under the car through a very small gap. Its been a few years since I last did it but used a length of wire with an appropriately shaped bend at the end and sprayed WD40 with a extra length tube to get the spray close to the actuator.
I cant give you an extract location of the gap unfortunately but it is one of those awkward places where you cant see without using a flashlight but the flashlight blocks the view of the actuator.
It has been covered many times and a search of the forum may get you more info.
Post #692905 18th May 2024 2:54pm
