Home > Maintenance & Mods (L405) > Top Hose Leak |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1190 |
Do you mean the thermostat housing if so don`t buy a new one just replace the `o` ring I had the same problem I bought the housing and it was just an `o` ring. 2017 SDV8 4.4 silicon silver AB
7th Jan 2023 12:12pm |
PLC Member Since: 23 May 2022 Location: Stafford Posts: 18 |
not the stat housing the actual top hose were it is fixed to the housing is leaking |
7th Jan 2023 12:19pm |
Probably just an `o` ring 2017 SDV8 4.4 silicon silver AB
7th Jan 2023 12:31pm |
been in touch with the parts department local r/r dealers the o ring is part of the hose assembly apparently and of a tapered design and not available seperately £140 + vat is the price they reckon |
7th Jan 2023 12:39pm |
Give these guys a go.https://www.barnwell.co.uk/o-rings-scotland/ 2017 SDV8 4.4 silicon silver AB
7th Jan 2023 12:47pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2492 |
I used a 45mm x 3.5mm Viton 75 o-ring. |
7th Jan 2023 7:45pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1499 |
@GraemeS
7th Jan 2023 8:17pm |
7th Jan 2023 8:23pm |
The original seal isn't an o-ring but I don't know of what it's made. The fitting for the top hose is subject to movement when the engine moves in its mounts so the seal wears, whereas the bottom hose can't move as it's braced to the engine. The 45x3.5mm o-ring makes the fitting very snug so perhaps won't move as much as the original, but I'll keep an eye on it as any leaks can be spotted without removing anything.
8th Jan 2023 2:24am |
Leon Member Since: 24 Apr 2024 Location: Wellington, New Zealand Posts: 3 |
26th Apr 2024 10:06am |
The small hose is part of the main hose which is part number LR080119. |
26th Apr 2024 11:00am |
Hello GraemeS,
26th Apr 2024 11:54am |
So it must be the other small hose that is part of the main assembly.
26th Apr 2024 12:42pm |
