Home > Maintenance & Mods (L405) > Top Hose Leak
PLC
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Top Hose Leak
Hello,
my 4.4 diesel sdv8 is leaking coolant from were the top hose joins the engine does anyone know if I can just replace the o ring seal or is it a new top hose job, thanks in advance
Post #652843 7th Jan 2023 11:50am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Do you mean the thermostat housing if so don`t buy a new one just replace the `o` ring I had the same problem I bought the housing and it was just an `o` ring. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #652844 7th Jan 2023 12:12pm
PLC
not the stat housing the actual top hose were it is fixed to the housing is leaking
Post #652847 7th Jan 2023 12:19pm
Tinman
Probably just an `o` ring Thumbs Up 2017 SDV8 4.4 silicon silver AB
Post #652849 7th Jan 2023 12:31pm
PLC
been in touch with the parts department local r/r dealers the o ring is part of the hose assembly apparently and of a tapered design and not available seperately £140 + vat is the price they reckon
Post #652850 7th Jan 2023 12:39pm
Tinman
Give these guys a go.https://www.barnwell.co.uk/o-rings-scotland/ 2017 SDV8 4.4 silicon silver AB
Post #652851 7th Jan 2023 12:47pm
GraemeS
I used a 45mm x 3.5mm Viton 75 o-ring.
Post #652905 7th Jan 2023 7:45pm
Gremlin500
@GraemeS
Probably a good idea to use Viton as its much more temperature resistant.
I wonder if the original was, given the number of failures of this item? Whistle
Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #652908 7th Jan 2023 8:17pm
PLC
the top hose connects to the pipe on the right I have been told the o ring is part of the hose connection
Post #652909 7th Jan 2023 8:23pm
GraemeS
The original seal isn't an o-ring but I don't know of what it's made. The fitting for the top hose is subject to movement when the engine moves in its mounts so the seal wears, whereas the bottom hose can't move as it's braced to the engine. The 45x3.5mm o-ring makes the fitting very snug so perhaps won't move as much as the original, but I'll keep an eye on it as any leaks can be spotted without removing anything.
Now 2 of the 3 spring clamps on the same hose must have lost their tension as on a recent 36 degC day coolant seeped from 2 hoses so screw clamps will be fitted shortly.
Update: The leak wasn't from the spring clamps around the main hose, instead from the screw clamp that I had fitted to my replacement brass spout and small hose which wasn't tight enough. The screw clamps will stay fitted though.
Post #652931 8th Jan 2023 2:24am
Leon
New Zealand 2016 Range Rover Vogue SE SDV8 Montalcino Red
Where does this hose go to? or the part number? The stork has snaped off the plastic elbow on the top hose of my L405 SDV8. This small hose disappears down the side of the radiator, but i can't see where it goes to. The parts screen does not shown this hose.
Post #691319 26th Apr 2024 10:06am
GraemeS
The small hose is part of the main hose which is part number LR080119.
Post #691321 26th Apr 2024 11:00am
Leon
Hello GraemeS,
no, this hose clips on to the plastic elbow, not part of LR080119. It goes down behind the horns.
Post #691328 26th Apr 2024 11:54am
GraemeS
So it must be the other small hose that is part of the main assembly.
Does it connect to the overflow bottle?
Post #691335 26th Apr 2024 12:42pm
